Airbag module location
2004 CHEVROLET COLORADO
112,000 MILES • 5 CYL • 2WD • AUTOMATIC
GUDUESTER
I need to know where the airbag module is located.
Thank you.
Feb 9, 2018 at 2:57 PM
CARADIODOC
  • 34,306 POSTS
There are six modules. If you are looking for the controller, GM calls it the "Inflatable Restraint Sensing and Diagnostic Module", (SDM). It is listed as "beneath the lower console". It should have a bright yellow connector.
Feb 9, 2018 at 3:13 PM
GUDUESTER
Thank you.
Well I am looking for the one that controls the airbags.
Feb 10, 2018 at 5:25 AM
CARADIODOC
  • 34,306 POSTS
That is the SDM in my previous reply. In the past, those had a "safing" sensor inside which is one of the crash sensors. In case yours has that, be sure that module is always bolted in the original orientation and tilt. Basically that means mounting it on the original bracket or mounts, with no modifications.
Feb 10, 2018 at 2:38 PM
