Airbag light reset
2007 FORD FIVE HUNDRED
99,500 MILES
RSEIFERT71
after servicing the driver side seat heater has an active airbag condition and I cannot figure out how to reset it. Ideas are welcome. It's also not the steering wheel clock spring, fyi.
Mar 26, 2021 at 6:33 AM
MHPAUTOS
  • 31,937 POSTS
You will have to run a diagnostic code check to see what has activated the check light, if a seat pressure sensor was unplugged and the ignition was cycled it will set a fault code, it may just be a simple code clear is all that is required. This will require a scanner with re set and code clear capability.Try this and let me know if you still have a problem.
Mark, (mhpautos)
Mar 27, 2021 at 4:41 AM
RSEIFERT71
Thanks Mark, I’ll give that a shot this afternoon and let you know. Thanks for your time. Just wasn’t sure if I would be able to reset without a scanner.
Mar 27, 2021 at 4:58 AM
I noticed that we haven't heard from you for a couple of days. Has any progress been made? We are interested in knowing.
Let me know,
Mar 29, 2021 at 7:37 PM
RSEIFERT71
Oh, I thought that I replied. Yes, the airbag light is reset. Thanks!
Mar 30, 2021 at 2:17 AM
Thanks for letting us know. Your response will likely help others.
Please feel free to come back any time in the future. You are always welcome.
Mar 30, 2021 at 5:53 PM
