Airbag light is on and fails to turn off after using scanner to turn it off
2011 TOYOTA COROLLA
4,567 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
MALLYBOY
  • 327 POSTS
The airbag light of this vehicle turns on and I diagnosed it, and it detects as follows:
1. B1801: Open in driver squib circuit
2. B1811: Open in driver squib circuit second step
3. B1906: Open in pretensioner circuit LH.
Then I began to check, and noticed that the seat belt pretensioner connector was not plugged in, I plugged it in, and changed the spiral cable, and the fault codes changed from:
B1801 changes to B1800
B1811 changes to B1810
B1906 remains, then I loop Positive and Negative circuit with wire, and it changes to B1905.
At this point, I become stocked, is it the steering pad and seat belt that need to be replaced?
Apr 10, 2022 at 1:45 PM
This is common when the clock spring or coil wire (same thing) goes out here is a general guide on how to fix it these specific instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Apr 11, 2022 at 10:02 AM
