Hi, I saw in You Tube the following:
''Hi Alec, Yes you are right for some models they don't need to be married, however for most models, generally speaking, these computers need to be programmed to the car.''
I have a 2008 Toyota Rav4 base model (2.5 liter) and by mistake both roof airbags deployed and both front seat retractors were activated.
My questions are:
- First, if I buy both used roof airbags and both seat belts with their retractor systems plus the SRS module from the same 2008 Rav4, will it work and will the airbag light go off? Will it need to be married to the rear seat belts and to the ECU?
-Second, if I buy both used roof airbags and both seat belts with their retractor systems without replacing the SRS module, will it work and will the airbag light go off?
-Third, will a good EBD2 be able to erase the codes from the existing SRS module in order to get the airbag light off?
Many thanks for taking the time to answer.
Gerard
My questions are:
Gerard
Jul 1, 2021 at 7:11 PM
