Intermittent airbag light turning on and off
2009 JEEP LIBERTY
98,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
MATTHEW SANGALANG
Hi, the airbag light goes on and off randomly when i drive the car, but mostly when I make turns. It seems to happen more often on city streets rather than highways. What could possibly make it go on and off and if i should replace anything?
Jan 3, 2020 at 7:30 PM
More than likely you have a wiring issue. It could be as simple as the clock spring but we need to check codes first. If the light is coming on there should be a stored code even if the light isn't on currently. More parts stores can pull codes just make sure their tool can communicate with ORC modules because some cannot.
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
Jan 3, 2020 at 7:57 PM
