Hello there, are you trying to just turn the light out? If that is the case you can probably just unplug it from the back of the instrument cluster. You have to be careful though with working with airbag systems. Do not just unplug airbags or any modules that have bright yellow wires. Those are the airbag system control wires and you can set off and airbag if you are not careful. Undo the battery negative and wait at least thirty minutes before doing anything. Better yet you might just want to leave it alone.
Aug 27, 2018 at 1:15 PM
