Airbag light bypass instructions needed
2008 KIA RIO
220,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
BRIAN372
  • 5 POSTS
How do I bypass the airbag light on the dash?
Aug 26, 2018 at 11:16 AM
AL514
  • 5,465 POSTS
Hello there, are you trying to just turn the light out? If that is the case you can probably just unplug it from the back of the instrument cluster. You have to be careful though with working with airbag systems. Do not just unplug airbags or any modules that have bright yellow wires. Those are the airbag system control wires and you can set off and airbag if you are not careful. Undo the battery negative and wait at least thirty minutes before doing anything. Better yet you might just want to leave it alone.
Aug 27, 2018 at 1:15 PM
BRIAN372
  • 5 POSTS
Great help you are.
Aug 27, 2018 at 7:59 PM
We cannot condone removing safety equipment.
Aug 27, 2018 at 8:00 PM
BRIAN372
  • 5 POSTS
I was not going to so.
Aug 27, 2018 at 9:44 PM
What can we help you with? Here is a video to run the codes so we can fix the problem which will probably be the clock spring for the steering wheel:
https://youtu.be/gnSGfEqrf_w
Aug 28, 2018 at 10:20 AM
BRIAN372
  • 5 POSTS
Watched the video and I cannot afford a code reader like that sir. I have used the regular ones so I imagine that is probably about $400.to to $500.00 if had that I would get fixed. Thank you very much for your insight to the problem but have a bigger problem I put a new ignition cylinder a new switch in in the same car erased the original key I guess, but it starts sometimes every time and then like it has no juice have start it from the starter relay it is getting old. Thanks
Aug 28, 2018 at 11:54 AM
That reader was $119.00 on Amazon. Here is the link:
https://www.amazon.com/gp/product/B07C7P1FSR/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B07C7P1FSR&linkId=17fe0f1a4746c6e6bfdb94baf101362d
Can you start a new question about the ignition switch so we do not mix the subject matter please?
Please post your new question here, you must be logged in.
Aug 29, 2018 at 10:04 AM
