Replaced middle air suspension valve block after all four air shocks drop evenly overnight. The compressor is good cause it raises all four air shocks in the morning if I turn on the on-road height. I can hear the compressor raising it. Unfortunately, after replacing the middle valve block, the dash shows suspension fault, and the compressor won't raise the vehicle. The switch will not turn on the off-road height. OBDII code C1A13. I replaced the air suspension compressor 2 years ago for the same suspension fault. I also tried resetting the suspension by turning the steering wheel lock to lock.
Jul 8, 2022 at 10:53 PM
