Recommendation needed as to where to purchase Air Shocks?
2005 MERCEDES BENZ ML500
40,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
LUIS MIGUEL APARICIO
MEMBER
1 POST
FOLLOW
Hi, the air shocks are bad, where do you recommend buying it from?
May 13, 2024 at 10:24 AM
STEVE W.
CERTIFIED EXPERT
I generally opt for the OE parts where possible, if you want aftermarket parts SKP and Westar both sell the replacement air springs for the front and rear units. There are also conversion kits that replace the OE parts with aftermarket struts and springs to remove the failure prone OE parts.
