Air ride system not working properly
1997 LINCOLN CONTINENTAL
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SAM SAMS
The system worked fine before it was parked. It has set for a few months. When you start the car the compressor wouldn't come on. The relay was bad so we replaced that. Now the compressor comes on but the rear of car still will not raise. During this you can hear a slight hissing sound near driver side rear tire. I can't tell if the sound is from air going in or air leaking out. All fuses and relays are good. Don't know if it could be the computer module or maybe level sensors.
Feb 19, 2019 at 7:04 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, the hissing sound you hear is air escaping. There are plastic air lines that attach to the rear air assemblies and are not holding air/leaking. Inspect the air lines for cracks/break/melt/deforms to see where the leak is coming from. Soapy water solution sprayed on it will also aid in finding the leak . Hope this helps and feel free to ask any further questions. Thanks for using 2CarPros.
Danny-
Feb 19, 2019 at 11:10 PM
SAM SAMS
Thank you Danny. I will check the lines and let you know if I have any further questions.
Feb 20, 2019 at 5:49 PM
DANNY L
  • 5,648 POSTS
Okay, let me know what happens.
Danny-
Feb 20, 2019 at 9:39 PM
