I’ve been trying to troubleshoot this for almost 2 weeks now. I replaced my front struts and shocks, and I noticed the vehicle was handling very poorly which led me to find out that air compressor was not kicking on. I have looked at every YouTube video imaginable as well as searched this forum. I’ve replaced every fuse associated with the ALC relay, including the relay itself. It will not come on with the computer. When I squeeze the rear shock cause there is no air prevalent in them at all. I replaced the compressor entirely just to make sure before I found out I could jump the pins. I did this and I did get it to come on. I do not seem to have power to pin 85 and the fuse is good. I’m not sure what else to do? I have also don’t have any codes showing on the dash. I’ve checked All three fuses spots (under hood, inside driver side dash, rear panel) and I don’t have any blown fuses. The only three things left I can think of are either a bad air ride sensor, bad ground or something wrong with the fuse block itself. This still doesn’t tell me why there’s no power with the vehicle running to pin 85. I’m at my wits end
Mar 30, 2026 at 7:08 AM
