Air Pump
1990 DODGE DAKOTA
223,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
BUCK211
  • 34 POSTS
The air pump on my truck has been ticking badly the last few days. My question has 2 parts,
#1. What is making the air pump tick?
#2. Can I remove the air pump without it bothering the truck?
Apr 19, 2017 at 2:29 PM
STEVE W.
  • 15,113 POSTS
If you mean the AIR pump that puts air into the exhaust system, the tick can be a bad check valve or internal pump damage. Hard to tell without hearing it up close.
As for removing it, you can BUT if you are in a state with emissions inspection it will fail, and I have seen more than once where removing the pump caused the catalytic converter to plug up because the extra air helps it to burn off the excess fuel. I would replace it with either a reman or a used pump.
Apr 19, 2017 at 5:13 PM
