air only comes through defrost, turning the knob to different settings does nothing?
2007 KIA SPECTRA
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVID SWAIN
MEMBER
1 POST
FOLLOW
Settings on the knob are the usual face/floor/defrost and max A/C. if actuator is the problem i need to know the location of the actuator.
Feb 28, 2025 at 3:57 AM
CERTIFIED EXPERT
It sounds like the mode door actuator isn't working or something has come apart. The actuator is located under the dash on the driver's side of the HVAC box.
If you look below, I attached a pic showing its location. The remaining pictures are the directions for replacing it.
I hope this helps. Let us know if you have additional questions.
