Air not blowing out of center dash vents
2015 NISSAN SENTRA
215,000 MILES
SSCHELLATO
  • 18 POSTS
Air doesn’t blow out of the vents in the center of the dashboard. It only blows out of the vents next to the doors when the corresponding mode is selected. It sometimes also doesn’t switch between defrost and other modes right away. Which part needs to be replaced and where is it located?
May 22, 2022 at 6:20 PM
It sounds like the mode door actuator is failing or could even be loose. I'm not sure if you have manual or automatic climate control, so I went with the manual.
If you look at the pics below, they are the directions for the removal and replacement of the mode door actuator. Take a look through them and let me know if they help.
See pics below. Note: If you have automatic climate control, let me know. Also, the last pic shows the location.
May 23, 2022 at 7:48 PM
SSCHELLATO
  • 18 POSTS
Thank you very much, this is very helpful. I do have the manual climate control. I’ll check if the motor is loose. If it’s not, I will replace it. Thanks again!
May 24, 2022 at 7:47 PM
You are very welcome. I hope it helps. If possible, let me know how things turn out for you. I'm interested in knowing.
May 24, 2022 at 7:53 PM
