How high is the battery voltage? Take a look through this link for testing:
If it is over or under charging, it will adversely affect different sensors, so we need to check what it's doing.
Next, you indicated the traction control light is on. Did the ABS light come on as well? If it did, is the brake fluid low? I know that sounds crazy, but it can cause this.
Now for the MAF. Disconnected and see if it runs better or worse. The vehicle will go into a preset operation with it disconnected and should change how it runs. If it does, replace the MAF.
Additionally, here is what I suggest. Because we have different modules involved, what should be done is this. Have the can-bus scanned for diagnostic trouble codes.
CAN stands for controller area network. Basically, all the different modules communicate with each other via a few wires. A traditional scan tool can't retrieve codes from most of the different modules, so you need one that can read all modules. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how to do what I'm referring to:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Also, let me know the exact code or codes you retrieved related to the MAF.
Nov 29, 2022 at 8:05 PM
