Sometimes it just stays running smooth, other times it just hiccups while in park like you see in the 1st video where the RPMs drop and come back and that's it. I put a new battery and just drove it and came up with this code P2774 air mass, plausibility: air mass too high (not present) but check engine light is on. It can also be called p00BD mass or volume air flow "A" circuit range performance-air flow too high
Under permanent codes which i think some were there from before i replaced the battery because there were so many codes then are:
P0100
P10f5
P00bc
P0172
When i first try to floor the gas pedal the RPMs dropped so i don't get the full normal throttle. The 2nd video shows that.
Also, i drive it around twice, if i stop and am still in gear it will stumble. I can turn it back on and if it stays in park it will not die but will hiccup.
P0100
P10f5
P00bc
P0172
Aug 26, 2022 at 4:03 PM
