I have had issues with acceleration going up hills' no power no obvious downshift of transmission- just flat. I am taking the car to a mechanic; I don't know much but I will have the timing checked. the belt was replaced at 50,000 miles, I am also replacing the throttle position sensor, idle air intake valve, as well as the MAP sensor and air intake temperature sensors, also the knock sensor; the labor rate is $130.00 an hour. Just please tell me what you think. these sensors have never been replaced; I will replace the (2) oxygen sensors myself. The scan called for PO325 knock sensor. Also the mass airflow sensor was just replaced. thanks, PATTYBOY
Nov 3, 2021 at 10:35 AM
