Thanks for the question. I see that you had another similar question. Please respond to this one as it is more clear as to what the issue is.
This is possible but I would expect it to set a code. Is the check engine light on? Have you checked for codes?
Next can you provide the different part numbers so that we can try to figure out if the sensors are different? It is possible that the sensors are different part numbers but they operate the same so that would not be the cause.
Did this issue start right after you replaced it? Do you have the original sensor? Can you install that one back in the engine and see if the stalling stops even if there was another with the other sensor?
Let us know. Thanks
Oct 11, 2020 at 2:39 PM
(Merged)
