Cabin air filter replacement and location
1999 TOYOTA RAV4
94,000 MILES • 2.0L • 4 CYL • 4WD
T L PHILLIPS
  • 4 POSTS
Hi, I would like to know where is located and possibly how to change the cabin air filter?
Aug 14, 2018 at 4:25 PM
I believe that Toyota did not start putting them in until 2001. However, if it does have one, it will be behind the glove box. Here is a link that shows in general how to replace one. You can check.
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Aug 14, 2018 at 10:05 PM
T L PHILLIPS
  • 4 POSTS
Yes thanks, I will be checking it out. Now, for my next question, sorry for so many. My battery post (positive side) the base of it, have a bit more than a hairline crack, actually, it is on the battery itself, is that normal for a battery to be like that? Seems as if that is what helps it corrode quickly. Is that normal, I do not remember seeing one like that before. Thanks for your help!
Aug 15, 2018 at 2:57 PM
Hi again. No, there should not be any cracks. Can you upload a picture of the crack so I can see exactly what it is?
Aug 15, 2018 at 7:46 PM
T L PHILLIPS
  • 4 POSTS
Hi, I am not good at transferring pictures from the phone to the computer. I will see if I can get help in doing it and let you know as soon as possible okay. Thank you very much.
Aug 16, 2018 at 9:59 AM
Glad to help. Honestly, there should not be any cracks in the top of the battery. Please remember that when a battery is being charged, it produces hydrogen, which is explosive. If you have to jump start the vehicle for any reason, make sure to follow the manufacturer's directions to avoid making sparks.
Again, let me know if I can help.
Aug 16, 2018 at 6:30 PM
