Air conditioning failure
2003 JAGUAR X-TYPE
143,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
PRRYPERRYS
  • 150 POSTS
I was driving Freon came through left vent; air conditioner immediately went hot and then the car started overheating.
Jul 28, 2020 at 3:15 AM
Good afternoon,
Are you sure it is not coolant from the heater core? If it did, and the car got hot, the ECM will not allow compressor operation.
Did you test the Freon pressures? You need to see if there is any pressure in the system.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
https://www.2carpros.com/articles/air-conditioner-leak-detection
I would also pressure test the cooling system as well.
https://www.2carpros.com/articles/replace-heater-core
https://www.2carpros.com/articles/radiator-pressure-test
Jul 28, 2020 at 1:33 PM
PRRYPERRYS
  • 150 POSTS
Hey Roy, thank you very much. I will check that out. I don't know I will be able to get under the hood on Sunday and then out reply to you. Thank you my friend.
Jul 28, 2020 at 4:09 PM
You are welcome.
Keep me updated.
Always glad to help.
Jul 28, 2020 at 4:21 PM
PRRYPERRYS
  • 150 POSTS
I will definitely keep you updated my friend thank you. Sorry for the misprints earlier. Kenny
Jul 28, 2020 at 7:54 PM
No worries.
Jul 29, 2020 at 4:10 AM
PRRYPERRYS
  • 150 POSTS
Hey Roy, hope all is well. thank you for your advice Perry on the Jaguar you was absolutely correct it is something to do with the heater core for heater hose . Because the air condition it's full of Freon so it wasn't Freon that came in my car. I just thought it was because A/C went hot I guess.. I am not a mechanic don't know too much about cars, but I do know there's something. I'm going to have to find a video and fix myself. any help would be appreciated. Kenny
Aug 7, 2020 at 7:52 AM
Okay, I attached the procedure below with some pictures. It is very tight under the dash but take your time. Remove the glove box and the heater box is right there.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Removal
1. NOTE: If a leak is suspected, the heater core must be leak tested in the vehicle before removal.
Drain the cooling system.
2. Disconnect the drain tube from the heater core.
3. Disconnect the heater hose from the heater core.
4. Disconnect the heater hose from the heater core.
5. Remove the center console.
6. Position the heater core air duct up.
1. Remove the heater core air duct retaining screw.
2. Position the heater core air duct up.
7. Remove the heater core air duct housing.
1. Remove the heater core air duct housing retaining screws.
2. Remove the heater core air duct housing.
Release the retaining tabs.
Right-hand side shown, left-hand side similar.
8. Remove the heater core housing retaining clips.
9. Remove the heater core housing
Release the heater core housing retaining tabs.
10. Remove the seal.
11. Remove the heater core retaining screw.
12. Remove the heater core.
Installation
1. To install, reverse the removal procedure.
Aug 7, 2020 at 8:14 AM
PRRYPERRYS
  • 150 POSTS
Hey Roy, awesome thank you very much. I think I can do that. I've changed the upper manifold is and lower manifold gaskets, o-rings, ignition coils and all that just from looking at videos. The hardest thing for me was finding the truck Ranch. But I will keep you informed, hopefully I can get to it tomorrow thank you, you guys are awesome.
Aug 7, 2020 at 9:52 AM
You are welcome.
Aug 7, 2020 at 9:54 AM
PRRYPERRYS
  • 150 POSTS
Good morning Roy hope all is well. I ran the Jaguar yesterday in the yard and let it overheat I noticed the fan did not kick on so that had to be steam that came through the vent. I'm thinking it's the fan control module because I had a new fan put on about a year ago. And I replace the fan control module with a used one about a year ago also . What do you think? Kenny oh and nothing leak out.
Aug 10, 2020 at 3:14 AM
Good morning,
Since we are away form the heater core or Freon subject, would you please start a new question from the beginning?
I will be glad to assist with the overheating.
Aug 10, 2020 at 3:34 AM
PRRYPERRYS
  • 150 POSTS
Hey Roy, I have a problem with my car overheating at idle . And I noticed the fan did not come on. Kenny
Aug 10, 2020 at 10:02 AM
Hi Kenny
As I stated, you need to go back to the beginning and start a new question. I cannot continue on this question since it was about the A/C system.
Aug 10, 2020 at 10:06 AM
PRRYPERRYS
  • 150 POSTS
Got it.
Aug 10, 2020 at 10:13 AM
Thanks.
Aug 10, 2020 at 11:11 AM
