Air conditioning compressor noise
2006 FORD E-SERIES VAN
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHRIS NIERADKA
A clicking noise is coming from my A/C compressor. Still works, but was hoping to repair before it gets worse. Could it be the clutch? Also, at certain rpm's the air will switch from face to defroster, then back. is this a vacuum leak in the control switch? How do I find it?
Jun 23, 2017 at 6:25 PM
CARADIODOC
  • 34,306 POSTS
If you see the compressor clutch cycling on and off rapidly, the system is low on refrigerant. That is real common on the Ford products that use quick-connect fittings on the hoses. They leak, and replacements will leak too.
The common complaint of switching to defrost has to do with acceleration more than engine speed. Under load, intake manifold vacuum goes down. Most heater systems are spring-loaded to default to defrost position if there is a problem with that vacuum. Your feet might freeze, but your windshield will be clear. Look under the hood for a small hard plastic vacuum line running to the firewall. There will be a check valve in that line. I am more familiar with those on Chrysler products. The valve is the size of a stack of three nickels. The dealer has a replacement that is about two inches long and 1 1/4" in diameter. It has a storage canister built in to prevent switching to defrost during those brief hard accelerations. The Ford dealer's parts department may have a similar solution.
Jun 23, 2017 at 6:33 PM
CHRIS NIERADKA
The clicking noise at the compressor is more like a rattle than the compressor cycling on, off. Maybe a bearing? When I first heard the noise, I thought something was hitting the radiator fan blade.
Jun 23, 2017 at 6:39 PM
CARADIODOC
  • 34,306 POSTS
Listen to the compressor with a stethoscope. There is not much to go wrong inside them, but you will hear it that way if something is coming apart. Also, look for a weak spring-loaded belt tension-er. They can vibrate from the increased load of the compressor.
Jun 24, 2017 at 7:05 PM
