LOL 73 is the new 40. I have a couple of questions for you. When this happens, do you lose cold air from all vents? For example, is it lost on both the passenger's side and the driver's side? Also, I need to know if you have automatic climate control or manual. Automatic is like your AC/heat at home. You set a desired temp and the system maintains it. Manual requires you to change it as desired.
One more question. I need to know the engine size.
I'm asking so many questions because there are two blend air door actuators. If only one side is affected, one of the actuator doors may have failed or become disconnected, allowing the door to move in the right direction under heavy acceleration. It is unlikely that both failed at the same time. Note that the blend door actuator is what determines the air temperature entering the vehicle. If the A/C compressor is working properly, this would be the next thing to check.
Jul 16, 2024 at 7:38 PM
