Air conditioning
2005 CHRYSLER PT CRUISER
42,000 MILES
BOBRACINE
Had the system vacuumed and recharged because it was cycling on and off. Second day after that it started recycling again. I looked for dye for leaks but see none.
Feb 7, 2018 at 2:49 PM
Good evening.
Do you have gauges to check the pressures?
It sounds like you have a leak, but the pressures will help.
Feb 7, 2018 at 3:22 PM
BOBRACINE
I checked for dye for leaks and found none. I am wondering about a sensor gone bad.
Feb 8, 2018 at 1:48 PM
I have found that when you can find the leak then the front seal of the compressor has gone bad. Sometimes they only leak when the system is on which it is difficult to check.
Here are two guides that will help you confirm the issue and get the problem fixed:
https://www.2carpros.com/articles/air-conditioner-leak-detection
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Check out the diagrams (below).
Feb 9, 2018 at 11:48 AM
BOBRACINE
i found it. there was a leak, i have ordered a new hose with o-rings. thanks
Feb 13, 2018 at 2:59 PM
