I have had two different mechanics work on truck. The air conditioner is blowing hot air. The Freon is leaking due to the fact they add it each timer. The pressure hose had a leak; replaced. It worked two weeks and stopped. They did not run dye through system? Dye was later run by second guy; took back could not find a leak. Then finally find An o-ring and another small part replaced. Worked for about a month. It is back blowing hot air again. Unverified A/C mechanic said must be evaporator? I am tired of being charged for all these visits but no solution.
Aug 19, 2017 at 5:24 AM
