Do I need to remove the expansion valve through the engine compartment?
2010 BUICK LA CROSSE
144,010 MILES • V6 • 4WD • AUTOMATIC
SUDHAMA GIBBONS
  • 5 POSTS
Or do I remove the glove compartment or dash to get to it? If I have to go through the engine compartment. What do I have to do?
Jul 14, 2022 at 3:11 PM
SQM
  • 6,383 POSTS
The expansion valve can be accessed from under the hood. You will have to remove some wires/hoses to get to it.
Let me know of any questions.
Thank you.
Jul 14, 2022 at 8:55 PM
SUDHAMA GIBBONS
  • 5 POSTS
How do I access the expansion valve in order to replace it?
Jul 16, 2022 at 6:04 PM (Merged)
SQM
  • 6,383 POSTS
The expansion valve is located on the firewall (see diagram below). You will have to remove the evaporator hose assembly to remove the expansion valve.
Keep in mind that before this can be completed the A/C system needs to be vacuumed down.
Here is a helpful guide:
I have attached a diagram below for your reference.
Thank you.
