I know there is enough Freon it. It is not sending the ground to the relay to make the compressor kick in.
I can put a ground wire to the relay and it will work.
The wiring diagram shows a light green wire going to the body control module and it comes from the AC control module. Is the light green wire a negative voltage or a positive voltage that goes to the body control module? It also shows a purple wire coming from the body control module and it goes to the power control module.
Is the purple wire a positive voltage or a negative voltage then the power control module sends the relay a negative voltage to make it work. Thank you
Mar 12, 2018 at 6:31 PM
