when i shut the A/C off and then turn it back on (the light on the switch does come on). it won't engage the compressor until i shut off the ignition, disconnect the battery a couple seconds and reconnect the battery, restart the engine and switch the A/C back on. also sometimes while driving, it quits cooling, the A/C must cycle off (the light on the switch is still on) and won't cool until i do the disconnect and reconnect battery procedure. (the light on the switch comes on, but no cooling happens unless i've performed the battery disconnect and reconnect procedure). could this be the relay not resetting? i have not changed the relay. Help!
Aug 26, 2021 at 6:21 PM
