I’m replacing my electrical blend door actuator and have it taken out. Right now, the only way the A/C will work is if the switch on the dash is set to defrost.
Normally I could put it to any mode (floor, vent, etc.) and the A/C would turn on when I pressed the button.
There is no blinking on the A/C button light and that same light will only turn on when pressed only with defrost selected.
Does the blend door actuator have to be installed in order for the A/C to work in the other modes?
Relays and fuses have been checked; all are good. Again, A/C works just fine only when in defrost.
Jun 12, 2023 at 10:26 PM
