Okay. That is way to high on a properly operating system. So we need the high side as well. If it is 90 PSI as well then the compressor is most likely the issue. However, if it is higher then normal also, then the system is either over full or you have a possible pressure sensor issue.
Either way, we need both the low and high side pressures with the engine running and A/C on and a static system, meaning engine off. Thanks
May 14, 2020 at 6:43 PM
