Air conditioner does not work.Heat comes out of vents even when off.
1998 FORD RANGER
129,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
SUE MARCUM
MEMBER
FOLLOW
Air conditioner does not work.Even when off.Heat continues to blow out vents.
Mar 20, 2016 at 11:16 PM
HMAC300
CERTIFIED EXPERT
try pulling hvac fuse in car it may be the blend door actuator and this will reset it. leave out for 60 seconds. if actuator is ok then the blend door shaft may be broken. there is a shortcut for that if you are so inclined. Check out the images (Below). Please let us know what happens.
Mar 21, 2016 at 2:19 PM
SUE MARCUM
MEMBER
Resetting the fuse did not help.Guess the door is broken.Someone said a hole had to be cut inside the blower box.Is there an easy way todo this?
Mar 22, 2016 at 1:15 PM
HMAC300
CERTIFIED EXPERT
it may not be a broken door take the actuator off and see if you can feel it move it may be just a bad actuator unless you have already found that the actuator moves.
Mar 22, 2016 at 1:21 PM
SUE MARCUM
MEMBER
Actuator moves.The piece inside act.door does turn.
Mar 22, 2016 at 2:09 PM
SUE MARCUM
MEMBER
Where is this fuse located?
Mar 22, 2016 at 3:53 PM
HMAC300
CERTIFIED EXPERT
after looking at this and your things with actuator door have you even seen that the compressor works? does it have pressure and does the large pipe leaving the evaporator under hood get frosty or feel cold when a/c is on? that may be the problem because I've been assuming that the a/c is in working order check that if compressor doesn't work then check fuse and relay underhood they will be marked for position on underpart or top of fuse box.
Mar 22, 2016 at 4:12 PM
HMAC300
CERTIFIED EXPERT
fuse 10 inside truck fuse box
Mar 22, 2016 at 4:34 PM
SUE MARCUM
MEMBER
When you turn ac on hot air blows out.And even if nothing is on.Hot air blows.
Mar 23, 2016 at 5:46 AM
HMAC300
CERTIFIED EXPERT
have this scanned for codes your blower motor module may be bad and letting blower motor work when it shouldn't . I have no further suggestions or comments
