The air conditioner light flashing indicates there's a problem detected. It can be an electrical problem or low freon (usually). If the air conditioning system has a leak that means air has gotten into the system and adding Freon doesn't always correct the issue because the air in the system needs to be removed with an A/C machine. If you visually look at all the air condition parts under the hood to look for residue on the hoses, compressor, condenser and air condition ports. There shouldn't be any residue on these parts around seals or hoses.
If you do see residue then that is a clue for a leak and those parts will need to be replaced as the freon will leak out again after removing the air from the system and recharging. Recovering all the freon on the system will determine how much freon was in the system and give an idea that the system has a leak also.
From your description it doesn't sound like it's an electrical fault as it sounds like everything is working electronically
Let us know what you find or if we can give you more direction.
Jun 21, 2024 at 9:07 AM
