Air conditioner not cooling properly
2009 VOLVO C30
30,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MAHFUZ097
Air conditioner is not working perfectly. It blows cold air during summer. The cooling and air flow is not accurate and the car does not cooling down. It blows speed is too little like 25% of its original flow. Looking for suggestions. Thank you in advance.
Jul 13, 2021 at 3:16 AM
SQM
  • 6,383 POSTS
So does the fan only blows at 25%? Are you able to adjust the speed of the blower fan? Or is it stuck in the low setting?
The A/C system might need to be recharged or there might be a clogged cabin air filter or a bad blower fan (or blower switch).
Check out this article for some helpful tips of A/C operations:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
https://youtu.be/4UjfQKvrB6Y
Please let me know some of these answers.
Thank you.
Jul 13, 2021 at 9:05 AM
MAHFUZ097
Hi again,
It blows too little at high speed. It is possible to regulate but does not make so much difference. At low speed it works like too little flow and at high speed it is increased but not as it should do. I am planning to recharge the A/C system.
Thank you for your support.
Jul 19, 2021 at 4:20 AM
SQM
  • 6,383 POSTS
Well, if you are unable to effectively change the speed of the air then your issue might be the blower motor or the blower switch.
Even if your A/C needs recharge, you still be able to increase/decrease the fan speed as normal. Only issue you would have is the temperature will not the ideal but the fan speed would be correct.
Do check your A/C to make sure it is fully charged, however if the issue does not change the blower fan is a good place to look. I have attached diagrams for your blower system.
Let me know of any questions.
Thank you.
Jul 19, 2021 at 6:34 AM
