Absolutely, Rhonda. There are pressure sensors on the unit, specifically, a low pressure sensor. If it is bad, it will indicate low pressure and the system won't turn on. However, you indicated it is working but only cool and not cold. Is that correct? If it is, then a sensor isn't the issue.
If you are certain the system Freon level is full, then we need to make sure the blend air door is working properly to allow full operation of the A/C. Tell me. Is this a manual or automatic system? Also, do you have duel climate control?
Did you have a chance to look through the link I attached above regarding nonworking or weak systems?
Thanks,
Apr 6, 2020 at 8:31 AM
