A/C not blowing very cold
2011 FORD FOCUS
116,500 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LSEDANO22
  • 4 POSTS
AC was blowing warm. Had it services, no leaks. New condenser fan, expansion vale, compressor and dryer receiver replaced system was flushed. It now blows at about 56-60 degrees. What can it be that it is not getting to the 50-40 degree level?
Thank you for any information. i can get
Aug 12, 2019 at 1:17 PM
Good afternoon,
What is the outside temperature?
What are the high and low side pressures for the system while running?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Aug 12, 2019 at 1:44 PM
LSEDANO22
  • 4 POSTS
92 temperature outside. I do not no the high low as I did not perform the service.
Aug 12, 2019 at 1:48 PM
At 92 degrees, 54 degrees duct temperature is normal.
Beyond that, I need the pressures.
Aug 12, 2019 at 1:51 PM
LSEDANO22
  • 4 POSTS
Okay, I will get that information. I can tell you that prior to the compressor being replaced. The low was reading extremely low and high was extremely high.
Aug 12, 2019 at 1:55 PM
Okay, let me know the readings when you can.
Aug 12, 2019 at 2:06 PM
