A/C not blowing cold air and there is a mist coming from the vents
2011 HOLDEN COMMODORE
120,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TREVOR RICHTER
When you put A/C on it does not get cold. Also seen a white mist come out of the vents.
Aug 20, 2021 at 4:23 AM
Sounds like we have a leak in the evaporator. However, we need to start with checking the pressures of the system. I suspect they are going to be low which means we have a leak somewhere. Then we need to pull it into a vacuum and add dye to the system and inspect the system for this dye. Here are some guides that will help with doing this:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Once we know what the pressures are and confirm they are low then we can take the next steps as we may have a different issue but I think this is what is going to be needed.
Below is a chart that will help with correct pressures. Please run through this info and let us know what you find and we can go from there. Thanks
Aug 20, 2021 at 7:50 AM
