Air Conditioner
2008 CHEVROLET
100,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
CONSTABLE198
  • 5 POSTS
The system has been re-gassed the correct amount and the compressor seems to cut in, but I still get air which is below outside temperature but not cold.
Any ideas please?
Thank you
Jul 7, 2017 at 4:12 AM
HMAC300
  • 48,601 POSTS
try pulling HVAC fuse inside car as it will reset actuators as the blend door actuator may need that. try that first.
Jul 7, 2017 at 6:46 AM
CONSTABLE198
  • 5 POSTS
Hello HMAC 300 Expert,
Thank you I will try that.
regards, Roger Lines
Jul 7, 2017 at 6:54 AM
Here are a couple of guides that will help you as well.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
and
Jul 9, 2017 at 1:04 PM
CONSTABLE198
  • 5 POSTS
Hello Ken
Thank you. Today I will follow these guides. The Air con fuse seems OK but I am unsure which relay it is and frankly Chevrolet themselves are not being too helpful but they are no longer here in Spain. I am grateful for your help
thank you ...rogerlines
Jul 10, 2017 at 2:12 AM
Please let us know what happens, we are interested to see what it is.
Jul 10, 2017 at 9:56 AM
CONSTABLE198
  • 5 POSTS
Hello Ken
Firstly, thanks for your help. Sorry for late reply, I have been busy building!
I pulled the fuse inside the car and under the bonnet. When I pull the fuse under the bonnet and push it back, I hear the compressor start. But the air is warm. I have changed the pollen filter.. The hot/cold adjustment rheostat next to the panel just turns continuously anti clock/clockwisebut it always has. All the tubes coming from the compressor are warm, one slightly hotter.
The air con expert here glibly says "new system 1000 euros". I am sure it is electrical fault somewhere
Thank you
Jul 14, 2017 at 7:10 AM
CONSTABLE198
  • 5 POSTS
Hello again Ken
Could you let me know where the blend door actuator is on a Chevrolet 16v 2L gm diesel Nubira please.
Thank you
Jul 14, 2017 at 7:16 AM
HMAC300
  • 48,601 POSTS
we have no info on that car as it. is not sold in usa
Jul 14, 2017 at 7:58 AM
