what exactly is it and if it is the coolant temperature sensor
2005 CHEVROLET CAVALIER
160,000 MILES • 2.2L • AUTOMATIC
RS SKUNO
I got the code engine ran for a car that i was buying and the air charge temperature sensor came back. I am wondering what exactly is it and if it is the coolant temperature sensor. i am also wondering if there are any videos out that has this replacement done, because i have looked and cannot find one for the car listed above. I already have the part which is the “ SU176VC “ part from AutoZone.
Apr 24, 2018 at 11:37 PM
SQM
  • 6,383 POSTS
The air charge temperature sensor also known as the intake air temperature (IAT). Is located on the base of the air intake tubing.
This sensor measures the incoming air to the engine to optimize fuel/ignition. It is not the same as the coolant temperature sensor, which measures the coolant temperature in the engine.
In order to replace the IAT you will have to remove the intake tubing.
I have attached the diagrams and replacement procedure below.
Thank you.
Oct 22, 2021 at 12:32 PM
