Air blowing only from driver vents with heat on
1998 OLDSMOBILE INTRIGUE
176,783 MILES • 2WD • AUTOMATIC
KRISTINE24
What can I check or do to get heat from both driver and passenger sides? Thank you
Nov 12, 2019 at 5:31 PM
Hi:
I need to confirm something. Are you getting cold air from the passenger side or is there no air flow? I ask because it is either a mode door actuator or a blend air door actuator and I don't want to give you the wrong information.
Nov 12, 2019 at 7:30 PM
