Airbag light turns off and back on
2004 JEEP GRAND CHEROKEE
122,000 MILES • 0.7L • V6 • 4WD • AUTOMATIC
CHUCKY 2020
The airbag light turned on. my horn, volume and cruise control stopped working. I had the clock spring replaced and everything works again. However, I drove it and then the airbag light turned on again. It turns off again but turns on again. Everything still works but the light turns on and off. What can be the issue?
Nov 18, 2019 at 6:11 PM
This could be a number of issues. If the light comes on it is best to scan for codes because if the light is on then there will be a code to go along with it. Just make sure the code reader is able to communicate with the ABS or it will return no codes.
Let me know what the codes are and we can go from there. Thanks
Nov 19, 2019 at 5:40 PM
