Hi Clarence,
More than likely your light is on because you have a issue with the system. Just resetting it will not correct it. We need to find out what codes are in the system which will tell us what part of the system is the issue.
If you don't have a code reader or scan tool, then most parts stores have the ability to pull the codes for you. Once you get the code, let me know what they are and I can get you more detail as to what the issue may be.
Jun 8, 2019 at 9:37 AM
