airbag light
2006 TOYOTA AVALON
75,000 MILES
ZION SUTTON
airbag light flashed three times then one after sixteen times. What could be problem?
Sep 19, 2017 at 11:40 AM
MHPAUTOS
  • 31,937 POSTS
These are the standard Toyota SRS flash codes, they are set in groups, the first group are 10's and the second group ate single digits, so three flashes -pause two flashes will be code 32. One flash-pause four flashes will be 14. re check what codes you are seeing and report back if the code is not on this list.
list of airbag flash codes.
12=Low Battery Voltage.
13=Air Bag Circuit Shorted to Ground.
14=Primary Crash Sensor Circuit Shorted to Ground.
21=Safing Sensor Not Mounted to Vehicle Properly.
22=Safing Sensor Output Shorted to Battery Voltage.
23=Safing Sensor Circuit Input Feed/Return Circuit Open.
24=Safing Sensor Output Feed/Return Circuit Open.
32 Driver Side Air Bag Circuit High Resistance or Open.
33 Passenger Side Air Bag Circuit High Resistance or Open.
34=Driver Side Air Bag Circuit Low Resistance or Shorted.
35=Passenger Side Air Bag Circuit Low Resistance or Shorted.
41=RH Primary Crash Sensor Feed/Return Circuit Open.
42=LH Primary Crash Sensor Feed/Return Circuit Open.
44=RH Primary Crash Sensor Not Mounted to Vehicle Properly.
45=LH Primary Crash Sensor Not Mounted to Vehicle Properly.
51=Air Bag Diagnostic Monitor Internal Thermal Fuse Blown Due to Intermittent Short to Ground.
52=Backup Power Supply Voltage Boost Fault.
53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault
k the flash sequence you have and check the list below.
Sep 20, 2017 at 4:39 AM
