Most commonly, the problem is related to the pressure sensor under the seat. Follow these simple steps to confirm there is not a problem with the connector.
Here is a link that will help when checking the connector and wiring:
Here are the directions for checking the connector and switch.
Faulty signal. Permanent fault
Checking components and wiring
- Ignition off
- Disconnect the battery negative terminal
- Disconnect the seat connector
- Check the connector for contact resistance and oxidation. See Checking wiring and terminals. Permanent fault See: Computers and Control Systems > Component Tests and General Diagnostics > Checking Wiring And Terminals. Permanent Fault
- If the seat connector is defective it must be replaced
If the connection is in good condition, the next steps require special tooling. I can provide them if needed.
I hope this helps. Let me know if you have other questions.
Oct 5, 2018 at 9:23 PM
