Code B1693, Airbag?
2015 TOYOTA CAMRY
130,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BUSINESSFRED
  • 91 POSTS
I scanned this SRS code: B1693 on the car listed above. I am looking to diagnose this issue and seeking diagrams or diagnostic steps to resolve The SRS code.
Aug 8, 2024 at 2:25 AM
Sure, this code means there is a problem with the passenger side occupant detection ECU which can happen because it is low in the car and can get wet and fail.
DTC B1693: Passenger Airbag ON/OFF Indicator Circuit
Sometimes it will be the sensor itself, they can get weak and stay on which will trigger this code, but I have seen the ECU go out many times. Here is how to change the passenger side occupant detection ECU which should fix it, please clear the codes once completed. Check out the images (below). Let us know what you find.
Aug 8, 2024 at 11:13 AM
