Code P0171?
1999 BUICK LESABRE
170,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
EARL91
  • 89 POSTS
I have the car listed above (limited model) obd2 indicates Code P0171. car is running too lean. I have replaced the fuel pump and sock. Replaced fuel sending unit new fuel filter. New O2 sensor bank one. Now the check engine light is flashing, and the car still sounds like a misfire and running rough if it runs at all. I replaced plugs wires and coil. What could be the next step to fix it? Please help.
Oct 21, 2022 at 5:36 PM
If the check engine light is flashing, that indicates a misfire is occurring. There should now be additional codes. Let me know what they are.
Now, in most cases, a lean mixture is the result of an engine vacuum leak. Have you checked for leaks?
Here is a link that explains how to check for leaks:
If you look below, I included the diagnostics for the P0171. Take a look through them and let me know if you are comfortable performing them.
See pics below.
Oct 21, 2022 at 10:22 PM
EARL91
  • 89 POSTS
Could my fuel sending unit not being sealed properly cause a vacuum leak?
Oct 30, 2022 at 7:40 AM
If you are referring to the sending unit in the fuel tank, I would say no unless there is a hose off to the EVAP system (charcoal canister.)
If you look below, I attached the vacuum schematic for the evap system. I tried to highlight where vapors go, which wasn't simple because my highlighter is too big. LOL
Anyway, that is about the only thing that I could think could happen if there was a problem in that area.
See pic below.
Oct 30, 2022 at 7:57 PM
