Aftermarket radio and amp will not turn on
2004 PONTIAC GRAND AM
174,000 MILES • 2WD • AUTOMATIC
DXMN
had the whole system running fine for about a year. battery dies charge it reconnect battery car starts.. no radio power or amp power.
Jan 14, 2020 at 12:01 PM
SCGRANTURISMO
  • 4,897 POSTS
Check the fuse that's in the back of the stereo. It's possible that the fuse has come loose. If it is blown then that is a separate problem that can be dealt with then. Please check the fuse and get back to. We can go from there if needed.
Thanks,
Alex
2CarPros
Jan 14, 2020 at 8:58 PM
DXMN
All fuses looked good. To be honest I do not know how the battery died in the first place my lights are auto. Thanks for the help.
Jan 15, 2020 at 10:01 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, you might want to check the antennae wire. A lot of aftermarket stereos use the antennae wire as a ground for the stereo. Also check the power and ground wires to the stereo and report back with what you find out.
Thanks,
Alex
2CarPros
Jan 15, 2020 at 5:13 PM
