Aftermarket amplifier installation
2016 FORD FUSION
30,587 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CRAZYDAVE909
i have the SE model with the sync 8.5" my-touch screen. it has the (four) door speakers and tweeters and (two) rear deck speakers. is there a amplifier in the rear i can get signal from to connect an external sub-woofer amplifier to?
Nov 3, 2017 at 8:47 AM
STEVE W.
  • 15,113 POSTS
You would need to tap the speaker outputs on the DAC for a signal. It is in the right rear behind the trim. But you may not like the results. The Fusion uses active noise control. IE: it listens to sounds inside/outside the vehicle and then sends sounds in the opposite waveform through the speakers to cancel out the sounds. Not sure what that will sound like coming through a sub-woofer that is not getting the same control signals.
Nov 3, 2017 at 11:38 AM
