I'm at the end of my rope... I'm a 25 year mechanic and I've done everything I can think of to my truck listed above 1500 so I've turned to the internet for help. The brakes were not working to par but were recently replaced so I knew that wasn't the issue. My first step was to replace the master cylinder, no dice, so I replaced the pressure modulator, again, no dice, so next was the ABS pump motor. third time's a charm, nope. so I replaced the ABS control unit - you've got to be kidding, and lastly, the vacuum brake booster. All to no avail! I did all of the correct bleeding each time and there's definitely no air in the system but the brakes go to the floor when I turn the truck on (hold pressure when truck is off?) and I'm at my wit's end! Any suggestions other than buying a new truck? FYI, rear brakes are disc brakes and mileage is about 207,000. Any help would be fantastic! Thank you!
May 22, 2021 at 10:51 PM
