So I bought a new radio from Walmart it is called dualcar is the brand it is a double din stereo for my car. I wired everything about ten times first it was not turning on and then magically it turned on one day and worked fine for a couple days and than started making this buzzing noise, but only when I turned on the headlights. I figured the ground wire was not connected right. So I took the thing apart and rewired everything. Now the radio has absolutely no sound I rewired everything over again still the same problem. I do not know what to do with it anymore I am very frustrated. I think it might just be the car being old because I had to switch a couple fuses in the process. At one point my whole dash board went dark I forgot to mention but that got fixed when the radio randomly turned on two days after I put it in. Please help any suggestions would be appreciated thanks!
Aug 6, 2017 at 10:56 PM
