After engine rebuild car will not start
2006 VOLKSWAGEN POLO
281,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
SHERPARD
  • 7 POSTS
Hi guys, had a oil pump failure and the piston connecting rod broke down so took the whole engine apart and put new crankshaft, oil pump two new pistons. now car cranks just fine, have spark, new battery, but still won't start. Please help.
Feb 9, 2020 at 10:15 AM
If you have spark and fuel, the timing is correct and you have engine compression, it has no choice but to run. Tell me, have you checked for fuel pressure? You indicated is has spark, so that isn't an issue.
Check fuel pressure and let me know what you find. Here is a link that explains how:
I will watch for your reply. Also, if you don't have a pressure gauge and can't get one, see if it starts for a couple seconds using starting fluid.
Feb 9, 2020 at 9:20 PM
SHERPARD
  • 7 POSTS
Hello Joe, the only thing I'm not sure about is the timing though I've heard several experts doing it for me.
Mar 9, 2020 at 1:24 AM
If you already checked fuel pressure, do me a favor. See if it starts for a couple seconds using starting fluid. If it does, then we will know it is a fuel related issue. If it has spark and won't start with starting fluid, chances are timing is off.
Let me know what you find.
Mar 9, 2020 at 9:05 PM
SHERPARD
  • 7 POSTS
Still nothing, I think the timing is off.
Mar 18, 2020 at 6:42 AM
It is very possible. If you can record the engine when it is cranking so I can hear it, I usually can tell if there is a timing issue just by sound. Often times people record with their phones and upload it from them.
Mar 18, 2020 at 12:10 PM
