If you still feel the abs engaging, chances are you have a bad wheel speed sensor. If the sensor is sending a signal, even if it is wrong, the light will stay out. The computer doesn't know if the sensor is accurate. It accepts the signal.
Here is what I suggest. There are wheel speed sensors at the wheels that can be checked. You will need a digital multimeter (DMM) to check. Here is a link that explains how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you look at pic 1 below, I highlighted the sensors. These are located behind the wheels and will be mounted in the steering knuckle in front and hub assembly in the rear.
Take care and God Bless,
Mar 5, 2021 at 10:21 PM
